Replace an I/O module in a FAS70 or FAS90 system
Replace an I/O module in your FAS70 or FAS90 system when the module fails or requires an upgrade to support higher performance or additional features. The replacement process involves shutting down the controller, replacing the failed I/O module, rebooting the controller, and returning the failed part to NetApp.
You can use this procedure with all versions of ONTAP supported by your storage system.
You must have the replacement part available.
Make sure all other components in the storage system are functioning properly; if not, contact technical support.
Always wear a grounded wrist strap connected to a verified ground point during installation and maintenance procedures. Failure to follow proper ESD precautions can cause permanent damage to controller nodes, storage shelves, and network switches. |
Step 1: Shut down the impaired node
Shut down or take over the impaired controller using one of the following options.
Take over and halt the impaired controller so that the healthy controller continues to serve data from the impaired controller's storage. To do this, you suppress automatic case creation in AutoSupport, disable automatic giveback, and bring the impaired controller to the LOADER prompt. The LOADER prompt is the safe halted state from which you can replace the FRU.
If you have a SAN system, you must have checked event messages (
cluster kernel-service show) for the impaired controller SCSI blade. Thecluster kernel-service showcommand (from priv advanced mode) displays the node name, quorum status of that node, availability status of that node, and operational status of that node.Each SCSI-blade process should be in quorum with the other nodes in the cluster. Any issues must be resolved before you proceed with the replacement.
If you have a cluster with more than two nodes, it must be in quorum. If the cluster is not in quorum or a healthy controller shows false for eligibility and health, you must correct the issue before shutting down the impaired controller; see Synchronize a node with the cluster.
If AutoSupport is enabled, suppress automatic case creation by invoking an AutoSupport message:
system node autosupport invoke -node * -type all -message MAINT=<number of hours down>hThis prevents automatic support cases from being opened during your planned maintenance window. The maximum suppression duration is 72 hours. If your maintenance completes early, you can re-enable case creation by invoking an AutoSupport message with
MAINT=END. For more information, see How to suppress automatic case creation during scheduled maintenance windows.The following AutoSupport message suppresses automatic case creation for two hours:
Disable automatic giveback:
Enter the following command from the console of the healthy controller:
Enter
ywhen you see the prompt Do you want to disable auto-giveback?
Take the impaired controller to the LOADER prompt:
If the impaired controller is displaying… Then… The LOADER prompt
Go to the next step.
Waiting for giveback…
Press Ctrl-C, and then respond
ywhen prompted.System prompt or password prompt
Take over or halt the impaired controller from the healthy controller:
storage failover takeover -ofnode impaired_node_name -halt trueThe -halt true parameter brings you to the LOADER prompt.
Do not use this procedure if your system is in a two-node MetroCluster configuration. |
If you have a MetroCluster configuration, you must have confirmed that the MetroCluster Configuration State is configured and that the nodes are in an enabled and normal state (
metrocluster node show).
cluster1:*> system node autosupport invoke -node * -type all -message MAINT=2h -
Disable automatic giveback from the console of the healthy controller:
storage failover modify –node local -auto-giveback false -
Go to the next Step.
ywhen prompted.System prompt or password prompt (enter system password)
Halt or take over the impaired controller from the healthy controller:
storage failover takeover -ofnode impaired_node_nameWhen the impaired controller shows Waiting for giveback…, press Ctrl-C, and then respond
y.
Step 2: Replace a failed I/O module
To replace an I/O module, locate it within the enclosure and follow the specific sequence of steps.
Unplug any cabling on the target I/O module.
Make sure that you label where the cables were connected, so that you can connect them to the correct ports when you reinstall the module. -
Rotate the cable management tray down by pulling the buttons on both sides on the inside of the cable management tray and then rotate the tray down.
This following illustration shows removing a horizontal and vertical I/O module. Typically, you will only remove one I/O module.
I/O cam latch
Make sure that you label the cables so that you know where they came from.
Remove the target I/O module from the enclosure:
Depress the cam button on the target module.
Rotate the cam latch away from the module as far as it will go.
Remove the module from the enclosure by hooking your finger into the cam lever opening and pulling the module out of the enclosure.
Make sure that you keep track of which slot the I/O module was in.
Set the I/O module aside.
Install the replacement I/O module into the enclosure:
Align the module with the edges of the enclosure slot opening.
Gently slide the module into the slot all the way into the enclosure, and then rotate the cam latch all the way up to lock the module in place.
Cable the I/O module.
Rotate the cable management tray up to the closed position.
Step 3: Reboot the controller
After you replace an I/O module, you must reboot the controller.
Reboot the controller from the LOADER prompt:
byeRebooting the impaired controller also reinitializes the I/O modules and other components. -
Return the impaired controller to normal operation by giving back its storage:
storage failover giveback -ofnode impaired_node_name -
Restore automatic giveback from the console of the healthy controller:
storage failover modify -node local -auto-giveback true -
If AutoSupport is enabled, restore automatic case creation:
Step 4: Return the failed part to NetApp
Return the failed part to NetApp, as described in the RMA instructions shipped with the kit. See the Part Return and Replacements page for further information.
