Review requirements for installing an AFF C30 or AFF C60 storage system
Review the requirements for installing your AFF C30 or AFF C60 storage system, including the equipment you need, lifting precautions, and site specifications, so that your installation goes smoothly.
Equipment needed for install
To install your storage system, you need the following equipment and tools.
Access to a Web browser to configure your storage system
Electrostatic discharge (ESD) strap
Flashlight
Laptop or console with a USB/serial connection
Phillips #2 screwdriver
Lifting precautions
Storage systems and shelves are heavy. Exercise caution when lifting and moving these items.
Storage system weight
Take the necessary precautions when moving or lifting your storage system.
The storage system can weigh up to 61.5 lbs (27.9 kg). To lift the storage system, use two people or a hydraulic lift.
Shelf weight
Take the necessary precautions when moving or lifting your shelf.
An NS224 shelf with NSM100B modules can weigh up to 56.8 lbs (25.8 kg). To lift the shelf, use two people or a hydraulic lift. Keep all components in the shelf (both front and rear) to prevent unbalancing the shelf weight.
After you've reviewed the installation requirements and considerations for your storage system, you prepare for installation.
