Two-post support rail kit installation instructions - AFF A700 and FAS9000
- PDF of this doc site
Creating your file...
Your file is ready
There are two, two-post support rail kits that can be used with the FAS9000 and AFF A700 systems. One kit allows you to flush-mount your system in the two-post rack, and the other kit allows you to mid-mount your system in the two-post rack.
