Install and maintain
AFX 1K chassis replacement workflow
Contributors netapp-driley netapp-jsnyder
Get started with replacing the chassis of your AFX 1K storage system by reviewing the replacement requirements, shutting down the controller, replacing the chassis, and verifying system operations.
Review the chassis replacement requirements.
Prepare to replace the chassis by locating the system, gathering system credentials and necessary tools, verifying the replacement chassis was received, and labeling the system cables.
Shut down the controller so you can perform maintenance on the chassis.
Replace the chassis by moving the components from the impaired chassis to the replacement chassis.
Complete the chassis replacement by bringing the controller up, giving back the controller, and returning the failed chassis to NetApp.
