Install and maintain
Shut down the impaired controller in an AFX 1K system
Contributors netapp-jsnyder netapp-driley
Shut down the impaired controller in your AFX 1K storage system to prevent data loss and ensure system stability when replacing the controller.
Shut down the controller module using one of the following options.
Take over and halt the impaired controller so that the healthy controller continues to serve data from the impaired controller's storage. To do this, you suppress automatic case creation in AutoSupport, disable automatic giveback, and bring the impaired controller to the LOADER prompt. The LOADER prompt is the safe halted state from which you can replace the FRU.
About this task
  • If you have a cluster with more than four nodes, it must be in quorum. To view cluster information about your nodes, use the cluster show command. For more information about the cluster show command, see View node-level details in an ONTAP cluster.
  • If the cluster is not in quorum or if the health or eligibility of any controller (other than the impaired controller) shows as false, you must correct the issue before shutting down the impaired controller. See Synchronize a node with the cluster.
Steps
  1. If AutoSupport is enabled, suppress automatic case creation by invoking an AutoSupport message:
    This prevents automatic support cases from being opened during your planned maintenance window. The maximum suppression duration is 72 hours. If your maintenance completes early, you can re-enable case creation by invoking an AutoSupport message with MAINT=END. For more information, see How to suppress automatic case creation during scheduled maintenance windows.
    The following AutoSupport message suppresses automatic case creation for two hours:
  2. Disable automatic giveback from the console of the impaired controller:
    storage failover modify -node impaired-node -auto-giveback-of false
    Note When you see Do you want to disable auto-giveback?, enter y.
    1. If you are running ONTAP version 9.17.1 and the impaired controller cannot be brought up or is already taken over, you must take the HA interconnect link down from the healthy controller before booting up the impaired controller. This prevents the impaired controller from performing automatic giveback.
      system ha interconnect link off -node healthy-node -link 0
      system ha interconnect link off -node healthy-node -link 1
  3. Take the impaired controller to the LOADER prompt:
    If the impaired controller is displaying…​ Then…​
    The LOADER prompt
    Go to the next step.
    System prompt or password prompt
    Take over or halt the impaired controller from the healthy controller: storage failover takeover -ofnode impaired_node_name -halt true
    The -halt true parameter brings the impaired node to the LOADER prompt.
What's next?
After shutting down the controller, replace the controller.
