Learn about adding and replacing I/O modules in an AFX 1K system
The AFX 1K storage system offers flexibility in expanding or replacing I/O modules to enhance network connectivity and performance. Adding an I/O module is essential when upgrading network capabilities. Replacing an I/O module is essential when addressing a failed module.
You can replace a failed I/O module in your AFX 1K storage system with the same type of I/O module, or with a different kind of I/O module. You can also add an I/O module into a system with empty slots.
Adding additional modules can improve redundancy, helping to ensure that the system remains operational even if one module fails.
Replacing a failing I/O module can restore the system to its optimal operating state.
The I/O slots on the AFX 1K controller are numbered 1 through 11, as shown in the following illustration.
