Shut down the controller in an AFX 2K system during the automated boot recovery process
Shut down the controller in your AFX 2K storage system to prevent data loss and ensure system stability when replacing the boot media.
Take over and halt the impaired controller so that the healthy controller continues to serve data from the impaired controller's storage. To do this, you suppress automatic case creation in AutoSupport, disable automatic giveback, and bring the impaired controller to the LOADER prompt. The LOADER prompt is the safe halted state from which you can replace the FRU.
If you have a cluster with more than four nodes, it must be in quorum. To view cluster information about your nodes, use the
cluster showcommand. For more information about thecluster showcommand, see View node-level details in an ONTAP cluster. -
If the cluster is not in quorum or if the health or eligibility of any controller (other than the impaired controller) shows as false, you must correct the issue before shutting down the impaired controller. See Synchronize a node with the cluster.
If AutoSupport is enabled, suppress automatic case creation by invoking an AutoSupport message:
system node autosupport invoke -node * -type all -message MAINT=<# of hours>hThe following AutoSupport message suppresses automatic case creation for two hours:
Disable automatic giveback from the console of the impaired controller:
storage failover modify -node impaired-node -auto-giveback-of falseWhen you see Do you want to disable auto-giveback?, enter y. -
Take the impaired controller to the LOADER prompt:
If the impaired controller is displaying… Then… The LOADER prompt
Go to the next step.
System prompt or password prompt
Take over or halt the impaired controller from the healthy controller:
storage failover takeover -ofnode impaired_node_name -halt trueThe -halt true parameter brings the impaired node to the LOADER prompt.
After shutting down the controller, change the boot media.
