Boot media replacement workflow - ASA A70 and ASA A90
- PDF of this doc site
Creating your file...
Follow these workflow steps to replace your boot media.
To replace the boot media, you must meet certain requirements.
Verify whether the system has security key manager enabled or encrypted disks.
Shut down or take over the impaired controller so that the healthy controller continues to serve data from the impaired controller storage.
Remove the failed boot media from the System Management module and install the replacement boot media, and then transfer an ONTAP image using a USB flash drive to the replacement boot media.
Boot the ONTAP image from the USB drive, restore the file system, and verify the environmental variables..
Restore the onboard key manager configuration or the external key manager from the ONATP boot menu.
Return the failed part to NetApp, as described in the RMA instructions shipped with the kit.
