Overview of replacing the boot media - ASA A1K
- PDF of this doc site
Creating your file...
Your file is ready
You can replace a failed boot media manually by using USB module for the boot image or through the automated boot media replace (BMR) option.
Automated boot media replacement
Automated boot media replace uses the boot image from the partned node and automatically runs the appropriate boot menu option to install the boot image to the replacement boot media.
Manual boot media replace uses the traditional method of downloading the ONTAP image from the NetApp support site, transferring the image to a USB drive, downloading it to the target replacement boot media, and manually walking through the boot menu options to install the ONTAP image on the replacement boot media.
