Boot media replace requirements - ASA A1K
- PDF of this doc site
Creating your file...
Your file is ready
Before replacing the boot media, make sure to review the following requirements.
You must have a USB flash drive, formatted to FAT32, with the appropriate amount of storage to hold the
image_xxx.tgz
You must copy the
image_xxx.tgz
file to the USB flash drive for later use in this procedure. -
You must replace the failed component with a replacement FRU component you received from your provider.
It is important that you apply the commands in these steps on the correct controller:
The impaired controller is the controller on which you are performing maintenance.
The healthy controller is the HA partner of the impaired controller.
