Install and maintain
ASA C30 chassis replacement workflow
Contributors netapp-jsnyder
Replacing the chassis in your ASA C30 storage system consists of reviewing the replacement requirements, shutting down the controllers, replacing the chassis, and verifying system operations.
Review the requirements to replace the chassis.
Shut down the controllers so you can perform maintenance on the chassis.
Replace the chassis by moving the drives and any drive blanks, controllers (with the power supplies), and bezel from the impaired chassis to the new chassis, and swapping out the impaired chassis with the new chassis of the same model as the impaired chassis.
Verify the HA state of the chassis and return the failed part to NetApp.
