Install and maintain
Replace the NV battery in an ASA C30 system
Contributors netapp-jsnyder netapp-lisa
Replace the NV battery in your ASA C30 storage system when the battery begins to lose charge or fails, as it is responsible for preserving critical system data during power outages. The replacement process involves shutting down the impaired controller, removing the controller module, replacing the NV battery, reinstalling the controller module, and returning the failed part to NetApp.
To replace the NV battery, you must remove the controller, remove the faulty battery, install the replacement battery, and then reinstall the controller.
Before you begin
All other components in the storage system must be functioning properly; if not, you must contact NetApp Support before continuing with this procedure.
About this task
If needed, you can turn on the storage system location (blue) LEDs to aid in physically locating the affected storage system. Log into the BMC using SSH and enter the system location-led on command.
A storage system has three location LEDs: one on the operator display panel and one on each controller. Location LEDs remain illuminated for 30 minutes.
You can turn them off by entering the system location-led off command. If you are unsure if the LEDs are on or off, you can check their state by entering the system location-led show command.
Step 1: Shut down the impaired controller
Take over and halt the impaired controller so that the healthy controller continues to serve data from the impaired controller's storage. To do this, you suppress automatic case creation in AutoSupport, disable automatic giveback, and bring the impaired controller to the LOADER prompt. The LOADER prompt is the safe halted state from which you can replace the FRU.
About this task
  • If you have a SAN system, you must have checked event messages (cluster kernel-service show) for the impaired controller SCSI blade. The cluster kernel-service show command (from priv advanced mode) displays the node name, quorum status of that node, availability status of that node, and operational status of that node.
    Each SCSI-blade process should be in quorum with the other nodes in the cluster. Any issues must be resolved before you proceed with the replacement.
  • If you have a cluster with more than two nodes, it must be in quorum. If the cluster is not in quorum or a healthy controller shows false for eligibility and health, you must correct the issue before shutting down the impaired controller; see Synchronize a node with the cluster.
Steps
  1. If AutoSupport is enabled, suppress automatic case creation by invoking an AutoSupport message:
    This prevents automatic support cases from being opened during your planned maintenance window. The maximum suppression duration is 72 hours. If your maintenance completes early, you can re-enable case creation by invoking an AutoSupport message with MAINT=END. For more information, see How to suppress automatic case creation during scheduled maintenance windows.
    The following AutoSupport message suppresses automatic case creation for two hours:
  2. Disable automatic giveback:
    1. Enter the following command from the console of the healthy controller:
    2. Enter y when you see the prompt Do you want to disable auto-giveback?
  3. Take the impaired controller to the LOADER prompt:
    If the impaired controller is displaying…​ Then…​
    The LOADER prompt
    Go to the next step.
    Waiting for giveback…​
    Press Ctrl-C, and then respond y when prompted.
    System prompt or password prompt
    Take over or halt the impaired controller from the healthy controller:
    The -halt true parameter brings you to the LOADER prompt.
Step 2: Remove the controller
You must remove the controller from the chassis when you replace the controller or replace a component inside the controller.
Before you begin
Make sure all other components in the storage system are functioning properly; if not, you must contact NetApp Support before continuing with this procedure.
Steps
  1. On the impaired controller, make sure the NV LED is off.
    When the NV LED is off, destaging is complete and it is safe to remove the impaired controller.
    Note If the NV LED is flashing (green), destage is in progress. You must wait for the NV LED to turn off. However, if the flashing continues for longer than five minutes, contact NetApp Support before continuing with this procedure.
    The NV LED is located next to the NV icon on the controller.
    NV status LED location
Callout number 1
NV icon and LED on the controller
Caution Always wear a grounded wrist strap connected to a verified ground point during installation and maintenance procedures. Failure to follow proper ESD precautions can cause permanent damage to controller nodes, storage shelves, and network switches.
  1. Disconnect the power on the impaired controller:
    Note Power supplies (PSUs) do not have a power switch.
    If you are disconnecting a…​ Then…​
    AC PSU
    1. Open the power cord retainer.
    2. Unplug the power cord from the PSU and set it aside.
    DC PSU
    1. Unscrew the two thumb screws on the D-SUB DC power cord connector.
  2. Unplug all cables from the impaired controller.
    Keep track of where the cables were connected.
  3. Remove the impaired controller:
    The following illustration shows the operation of the controller handles (from the left side of the controller) when removing a controller:
    controller handle operation to remove a controller
    Callout number 1
    On both ends of the controller, push the vertical locking tabs outward to release the handles.
    Callout number 2
    • Pull the handles towards you to unseat the controller from the midplane.
      As you pull, the handles extend out from the controller and then you feel some resistance, keep pulling.
    • Slide the controller out of the chassis while supporting the bottom of the controller, and place it on a flat, stable surface.
    Callout number 3
    If needed, rotate the handles upright (next to the tabs) to move them out of the way.
  4. Open the controller cover by turning the thumbscrew counterclockwise to loosen, and then open the cover.
Step 3: Replace the NV battery
Remove the failed NV battery from the controller and install the replacement NV battery.
Steps
  1. If you are not already grounded, properly ground yourself.
  2. Locate the NV battery.
  3. Remove the NV battery:
    Callout number 1
    Lift the NV battery up and out of its compartment.
    Callout number 2
    Remove the wiring harness from its retainer.
    Callout number 3
    1. Push in and hold the tab on the connector.
    2. Pull the connector up and out of the socket.
      As you pull up, gently rock the connector from end to end (lengthwise) to unseat it.
  4. Install the replacement NV battery:
    1. Remove the replacement battery from its package.
    2. Plug the wiring connector into its socket.
    3. Route the wiring along the side of the power supply, into its retainer, and then through the channel in front of the NV battery compartment.
    4. Place the NV battery into its compartment.
      The NV battery should sit flush in its compartment.
Step 4: Reinstall the controller
Reinstall the controller into the chassis and reboot it.
About this task
The following illustration shows the operation of the controller handles (from the left side of a controller) when reinstalling the controller, and can be used as a reference for the rest of the controller reinstallation steps.
controller handle operation to install a controller
Callout number 1
If you rotated the controller handles upright (next to the tabs) to move them out of the way while you serviced the controller, rotate them down to the horizontal position.
Callout number 2
Push the handles to reinsert the controller into the chassis halfway and then, when instructed, push until the controller is fully seated.
Callout number 3
Rotate the handles to the upright position and lock in place with the locking tabs.
Steps
  1. Close the controller cover and turn the thumbscrew clockwise until tightened.
  2. Insert the controller halfway into the chassis.
    Align the rear of the controller with the opening in the chassis, and then gently push the controller using the handles.
    Note Do not completely insert the controller in the chassis until instructed to do so.
  3. Connect the console cable to the console port on the controller and to the laptop so that the laptop receives console messages when the controller reboots.
    Note Do not connect any other cables or power cords at this time.
  4. Fully seat the controller in the chassis:
    1. Firmly push on the handles until the controller meets the midplane and is fully seated.
      Note Do not use excessive force when sliding the controller into the chassis; it could damage the connectors.
    2. Rotate the controller handles up and lock in place with the tabs.
      Note The replacement controller receives power from the healthy controller and begins to boot as soon as it is fully seated in the chassis.
  5. Recable the controller as needed.
  6. Reconnect the power cord to the power supply (PSU).
    Once power is restored to the PSU, the status LED should be green.
    If you are reconnecting a…​ Then…​
    AC PSU
    1. Plug the power cord into the PSU.
    2. Secure the power cord with the power cord retainer.
    DC PSU
    1. Plug the D-SUB DC power cord connector into the PSU.
    2. Tighten the two thumb screws to secure the D-SUB DC power cord connector to the PSU.
  7. Return the impaired controller to normal operation by giving back its storage:
    storage failover giveback -ofnode impaired_node_name
  8. Restore automatic giveback from the console of the healthy controller:
  9. If AutoSupport is enabled, restore (unsuppress) automatic case creation:
Step 5: Return the failed part to NetApp
Return the failed part to NetApp, as described in the RMA instructions shipped with the kit. See the Part Return and Replacements page for further information.
