Install and maintain
FAS70 and FAS90 chassis replacement workflow
Contributors netapp-jsnyder dougthomp
Get started with replacing the chassis of your FAS70 or FAS90 storage system by reviewing the replacement requirements, shutting down the controller, replacing the chassis, and verifying system operations.
Review the chassis replacement requirements.
Prepare to replace the chassis by locating the system, gathering system credentials and necessary tools, verifying the replacement chassis was received, and labeling the system cables.
Shut down the controller so you can perform maintenance on the chassis.
Replace the chassis by moving the components from the impaired chassis to the replacement chassis.
Complete the chassis replacement by bringing the controller up, giving back the controller, and returning the failed chassis to NetApp.
