Key specifications for FAS70
The following are select specifications for the FAS70 storage system in a single high availability pair. Visit NetApp Hardware Universe (HWU) for the complete specifications for this storage system.
FAS70 specifications at a glance
Platform Configuration: FAS70 Dual Chassis HA Pair
Max Raw Capacity: 15.0000 PB
Memory: 256.0000 GB
Form Factor: 2U chassis with 1 HA controllers
ONTAP Version: ONTAP: 9.16.1P2
PCIe Expansion Slots: 18
Minimum ONTAP Version: ONTAP 9.15.1 == Scaleout maximums
Type: NAS; HA Pairs: 12; Raw Capacity: 180.0 PB / 159.9 PiB; Max Memory: 3072 GB
Type: SAN; HA Pairs: 6; Raw Capacity: 90.0 PB / 79.9 PiB; Max Memory: 1536 GB
Type: HA Pair; Raw Capacity: 15.0 PB / 13.3 PiB; Max Memory: 256.0000
I/O
Onboard I/O
No onboard I/O data.
Total I/O
Protocol: Ethernet 200 Gbps; Ports: 20
Protocol: Ethernet 100 Gbps; Ports: 32
Protocol: Ethernet 25 Gbps; Ports: 48
Protocol: Ethernet 10 Gbps; Ports: 48
Protocol: FC 64 Gbps; Ports: 48
Protocol: NVMe/FC 64 Gbps; Ports: 48
Ports: 0
Protocol: SAS 12 Gbps; Ports: 48
Management ports
Protocol: Ethernet 1 Gbps; Ports: 2
Protocol: RS-232 115 Kbps; Ports: 4
Protocol: USB 600 Mbps; Ports: 2
Storage networking supported
CIFS
FC
iSCSI
NFS v3
NFS v4.0
NFS v4.1
NFS v4.2
NVMe/FC
NVMe/TCP
S3
S3 with NAS
SMB 2.0
SMB 2.1
SMB 2.x
SMB 3.0
SMB 3.1
SMB 3.1.1 == System environment specifications
Typical Power: 2653 BTU/hr
Worst-case Power: 3050 BTU/hr
Weight: 59.5 lb 27.0 kg
Height: 2U
Width: 19” IEC rack-compliant (17.7” 44.9 cm)
Depth: 30.0” (35.2” with cable management bracket)
Operating Temp/Altitude/Humidity: 10°C to 35°C 50°F to 95°F) at ⇐ 3048m ⇐ 10000 ft) elevation;8% to 80% relative humidity, noncondensing
Non-operating Temp/Humidity: -40°C to 70°C (-40°F to 158°F) upto 12192m (40000 ft) 10% to 95% relative humidity, noncondensing, in original container
Acoustic Noise: Declared sound power (LwAd): 8.5 Sound pressure (LpAm) (bystander positions): 67.7 dB
Compliance
Certifications EMC/EMI: AMCA, FCC, ICES, KC, Morocco, VCCI
Certifications safety: BIS, CB, CSA, G_K_U-SoR, IRAM, NOM, NRCS, SONCAP, TBS
Certifications Safety/EMC/EMI: EAC, UKRSEPRO
Certifications Safety/EMC/EMI/RoHS: BSMI, CE DoC, UKCA DoC
Standards EMC/EMI: BS-EN-55032, BS-EN55035, CISPR 32, EN55022, EN55024, EN55032, EN55035, EN61000-3-2, EN61000-3-3, FCC Part 15 Class A, ICES-003, KS C 9832, KS C 9835
Standards Safety: ANSI/UL60950-1, ANSI/UL62368-1, BS-EN62368-1, CAN/CSA C22.2 No. 60950-1, CAN/CSA C22.2 No. 62368-1, CNS 15598-1, EN60825-1, EN62368-1, IEC 62368-1, IEC60950-1, IS 13252(part 1)
High availability
Ethernet based baseboard management controller (BMC) and ONTAP management interface
Redundant hot-swappable controllers
Redundant hot-swappable power supplies
SAS in-band management over SAS connections for external shelves
