Install and maintain
Key specifications for FAS90
Contributors Grantglass
The following are select specifications for the FAS90 storage system in a single high availability pair. Visit NetApp Hardware Universe (HWU) for the complete specifications for this storage system.
FAS90 specifications at a glance
  • Platform Configuration: FAS90 Dual Chassis HA Pair
  • Max Raw Capacity: 15.0000 PB
  • Memory: 1024.0000 GB
  • Form Factor: 2U chassis with 1 HA controllers
  • ONTAP Version: ONTAP: 9.16.1P2
  • PCIe Expansion Slots: 18
  • Minimum ONTAP Version: ONTAP 9.15.1 == Scaleout maximums
  • Type: NAS; HA Pairs: 12; Raw Capacity: 180.0 PB / 159.9 PiB; Max Memory: 12288 GB
  • Type: SAN; HA Pairs: 6; Raw Capacity: 90.0 PB / 79.9 PiB; Max Memory: 6144 GB
  • Type: HA Pair; Raw Capacity: 15.0 PB / 13.3 PiB; Max Memory: 1024.0000
I/O
Onboard I/O
No onboard I/O data.
Total I/O
  • Protocol: Ethernet 200 Gbps; Ports: 20
  • Protocol: Ethernet 100 Gbps; Ports: 32
  • Protocol: Ethernet 25 Gbps; Ports: 48
  • Protocol: Ethernet 10 Gbps; Ports: 48
  • Protocol: FC 64 Gbps; Ports: 48
  • Protocol: NVMe/FC 64 Gbps; Ports: 48
  • Ports: 0
  • Protocol: SAS 12 Gbps; Ports: 48
Management ports
  • Protocol: Ethernet 1 Gbps; Ports: 2
  • Protocol: RS-232 115 Kbps; Ports: 4
  • Protocol: USB 600 Mbps; Ports: 2
Storage networking supported
  • CIFS
  • FC
  • iSCSI
  • NFS v3
  • NFS v4.0
  • NFS v4.1
  • NFS v4.2
  • NVMe/FC
  • NVMe/TCP
  • S3
  • S3 with NAS
  • SMB 2.0
  • SMB 2.1
  • SMB 2.x
  • SMB 3.0
  • SMB 3.1
  • SMB 3.1.1 == System environment specifications
  • Typical Power: 3392 BTU/hr
  • Worst-case Power: 5136 BTU/hr
  • Weight: 59.5 lb 27.0 kg
  • Height: 2U
  • Width: 19” IEC rack-compliant (17.7” 44.9 cm)
  • Depth: 30.0” (35.2” with cable management bracket)
  • Operating Temp/Altitude/Humidity: 10°C to 35°C 50°F to 95°F) at ⇐ 3048m ⇐ 10000 ft) elevation;8% to 80% relative humidity, noncondensing
  • Non-operating Temp/Humidity: -40°C to 70°C (-40°F to 158°F) upto 12192m (40000 ft) 10% to 95% relative humidity, noncondensing, in original container
  • Acoustic Noise: Declared sound power (LwAd): 8.5 Sound pressure (LpAm) (bystander positions): 67.7 dB
Compliance
  • Certifications EMC/EMI: AMCA, FCC, ICES, KC, Morocco, VCCI
  • Certifications safety: BIS, CB, CSA, G_K_U-SoR, IRAM, NOM, NRCS, SONCAP, TBS
  • Certifications Safety/EMC/EMI: EAC, UKRSEPRO
  • Certifications Safety/EMC/EMI/RoHS: BSMI, CE DoC, UKCA DoC
  • Standards EMC/EMI: BS-EN-55032, BS-EN55035, CISPR 32, EN55022, EN55024, EN55032, EN55035, EN61000-3-2, EN61000-3-3, FCC Part 15 Class A, ICES-003, KS C 9832, KS C 9835
  • Standards Safety: ANSI/UL60950-1, ANSI/UL62368-1, BS-EN62368-1, CAN/CSA C22.2 No. 60950-1, CAN/CSA C22.2 No. 62368-1, CNS 15598-1, EN60825-1, EN62368-1, IEC 62368-1, IEC60950-1, IS 13252(part 1)
High availability
  • Ethernet based baseboard management controller (BMC) and ONTAP management interface
  • Redundant hot-swappable controllers
  • Redundant hot-swappable power supplies
  • SAS in-band management over SAS connections for external shelves
