Install and maintain
Replacement reference for NetApp storage systems
Contributors netapp-martyh netapp-jsnyder
Find replacement procedures for your NetApp storage system organized by component type. This reference provides direct links to step-by-step replacement workflows for AFF, ASA, and FAS systems to help you quickly locate the correct procedure for your specific hardware maintenance needs.
System component
Boot media replacement procedures
The boot media stores a primary and secondary set of boot image files that the system uses when it boots.
Caching module replacement procedures
You must replace the controller's caching module when your system registers a single AutoSupport (ASUP) message that the module has gone offline.
Chassis replacement procedures
The chassis is the physical enclosure housing all the controller components, such as the controller/CPU unit, power supply, and I/O.
Controller replacement procedures
A controller consists of a board, firmware, and software. It controls the drives and implements the ONTAP functions.
DCPM power module replacement procedures
The data center persistent memory (DCPM) power module provides backup power for DCPM modules during unexpected power loss events.
DIMM replacement procedures
You must replace a DIMM (dual in-line memory module) when a memory mismatch is present, or you have a failed DIMM.
Drive replacement procedures
A drive is a device that provides the physical storage media for data.
Fan replacement procedures
A fan provides airflow for cooling system components and maintaining proper operating temperatures.
IO module replacement procedures
An I/O module provides network and storage connectivity interfaces for the controller.
LED module replacement procedures
The LED module provides visual status indicators for system health and component status.
Mezzanine replacement procedures
A mezzanine card provides additional I/O connectivity and expansion capabilities for the controller.
NVDIMM replacement procedures
You must replace an NVDIMM (non-volatile dual in-line memory module) when the module fails or shows errors.
NVMEM/NVRAM battery replacement procedures
A battery is included with a controller and preserves cached data if the AC power fails.
NVRAM module replacement procedures
The NVRAM module provides non-volatile storage for system metadata and cached write data.
PCI cards and risers replacement procedures
PCI cards and risers provide expansion slots for additional functionality and I/O connectivity.
Power supply replacement procedures
A power supply provides a redundant power source in a controller shelf.
RTC battery replacement procedures
A real-time clock battery preserves system date and time information if the power is off.
System management module replacement procedures
The system management module provides out-of-band management capabilities for the system.
