How NetApp AFX architecture differs from unified ONTAP
NetApp AFX introduces significant architectural differences from unified ONTAP in how storage is presented, how nodes interact with disks, and how capacity is managed.
Previously, we showed a general picture of how unified ONTAP architecture delivers file, object, and block data storage via directly connected HA pairs that own their own sets of disks and present physical capacity via aggregates of disks. In this section, we'll discuss some of the major differences between unified ONTAP and NetApp AFX architectures in further detail.
How to tell if a system is running NetApp AFX
The main way to see if your system is running NetApp AFX is to run the following command:
AFX::> node show -fields personality node personality ---------------- ----------- afx-01 AFX afx-02 AFX
Another clue is the new Storage Availability Zone, but that is also a concept available to NetApp All-SAN Arrays (ASA). You can see your capacity via that command.
AFX::> storage availability-zone show
Availability Zone Name: storage_availability_zone_0
Availability Zone UUID: 545cb59f-32e9-11f1-a2f5-d039eabdd925
Total Size: 69.59TB
Physical Used: 837.1GB
Physical Used Percent: 1%
Available: 68.77TB
Metadata Used: 837.1GB
Log and Recovery Metadata: 834.6GB
Delayed Frees: 2.50GB
Physical User Data Without Snapshot Copies: 17.24MB
Logical User Data Without Snapshot Copies: 17.24MB
Efficiency Ratio Without Snapshot Copies: 1.00:1
Space Full Threshold Percent: 98%
Space Nearly Full Threshold Percent: 95%
