NetApp Technical Reports
ONTAP FlexCache and FlexGroup volume technical reports
Contributors netapp-chrisgeb netapp-dbagwell netapp-aherbin
NetApp NAS solutions simplify data management and help you keep pace with growth while optimizing costs. ONTAP NAS solutions give you nondisruptive operations, proven efficiency, and seamless scalability within a unified architecture. Powered by ONTAP, scale-out NAS leverages the massive ONTAP ecosystem, with a significant innovation lead and vision for aggressive future innovation.
Note
These technical reports expand on the ONTAP FlexCache volume and ONTAP FlexGroup volume product documentation.
FlexCache
TR-4743: FlexCache in ONTAP
FlexCache is a caching technology that creates sparse, writable replicas of volumes on the same or different ONTAP clusters. It can bring data and files closer to the user for faster throughput with a smaller footprint. Learn how FlexCache can be used, the recommended practices, limits, and considerations for design and implementation.
FlexCache write-back
Introduced in ONTAP 9.15.1, FlexCache write-back is an alternate mode of operation for writing at a cache. Write-back allows the write to be committed to stable storage at the cache and acknowledged to the client without waiting for the data to make it to the origin. The data is asynchronously flushed back to the origin. The result is a globally distributed file system that enables writes to perform at near-local speeds for specific workloads and environments, offering significant performance benefits.
FlexGroup volumes
TR-4571: NetApp ONTAP FlexGroup volumes best practices and implementation guide
Learn about FlexGroup volumes, recommended practices and implementation tips. FlexGroup volumes are an evolution of ONTAP scale-out NAS containers, that blends nearly infinite capacity with predictable, low latency performance in metadata-heavy workloads.
TR-4678: Data protection and backup of FlexGroup volumes
Learn about data protection and backup for FlexGroup volumes including Snapshot copies, SnapMirror, and other data protection and backup solutions.
