ONTAP Technical Reports
Use cases and workloads
NFS over TLS is a good fit for three common deployment scenarios: on-wire encryption without a Kerberos infrastructure, per-client TLS enforcement on a shared export, and mutual client authentication.
Not every workload benefits equally — knowing the patterns that fit and the ones that don't will help you plan your deployment.
Use cases
On-the-wire NFS encryption without a Kerberos infrastructure.
If you need NFS data-in-transit encryption but don't want to deploy and operate a Key Distribution Center (KDC), distribute keytabs to clients, or extend a Kerberos realm to cover your NAS clients, NFS over TLS solves this directly. You install a server certificate per Storage Virtual Machine (SVM), enable NFS over TLS on each data Logical Interface (LIF) that should carry encrypted NFS, and clients negotiate TLS 1.3 in-band on the standard NFS port. No new authentication service required.
Per-client TLS-only enforcement on a shared NFS export.
If you have a mix of encryption-required clients and clients that don't need encryption, you need a way to force the regulated clients onto the encrypted path without breaking the others. The export-policy rule option -allow-nfs-tls-only true does exactly that. It denies non-TLS mounts from matching clients over TCP while leaving other export-policy rules untouched.
Mutual client authentication (mTLS) for storage-to-client trust.
If you're operating under zero-trust networking principles or have hardening requirements that mandate the storage controller verify the host identity of every connecting client, use the per-LIF mutual TLS option. Set -enforce-host-auth true on vserver nfs tls interface enable or vserver nfs tls interface modify. ONTAP then validates each connecting client's X.509 certificate against the SVM's installed Certificate Authority (CA) trust chain at TLS handshake time and rejects clients that don't present a trusted certificate. This gives you cryptographic enforcement of "only my registered host fleet can reach this NFS LIF" and operates in addition to existing export-policy host filters.
Workloads
Encryption is not free. The TLS handshake has a measurable cost, and TLS record encryption adds overhead to every RPC. The performance impact varies widely based on workload, platform, and whether hardware offload is available. For details, see Performance.
Workload patterns
Long-lived NFS mounts with a stable client population are a great fit. The TLS handshake is a per-connection cost paid at mount time and at session re-establishment—​if you have a small, stable set of clients that mount once and stay mounted for hours or days, you'll absorb that cost cleanly.
If you already manage LIF-to-hostname mapping cleanly—​for example, with DNS records under your control—​you'll find NFS over TLS straightforward to provision. The feature is configured per-LIF: you install a server certificate whose Common Name (CN) matches the LIF's Fully Qualified Domain Name (FQDN) and whose Subject Alternative Name (SAN) list contains the LIF's IP address.
NFS over TLS is the right tool when on-wire confidentiality, server identity, and optionally client host identity are your security requirements—​exactly the properties TLS delivers.
Workload anti-patterns
High connection churn or large mount storms are a poor fit. Every new TLS connection pays the TLS 1.3 handshake cost, including asymmetric cryptography, certificate validation, and optional mTLS chain validation. If many clients mount, do a small amount of work, unmount, and reconnect repeatedly, you'll pay that handshake cost over and over rather than amortizing it.
