ONTAP tools for VMware vSphere 10
Learn about ONTAP tools for VMware vSphere
Contributors netapp-jani jani
ONTAP tools for VMware vSphere is a set of tools for virtual machine lifecycle management. It integrates with the VMware ecosystem to simplify datastore provisioning and provide basic protection and disaster recovery for virtual machines. Deployed as an Open Virtual Appliance (OVA), it uses horizontally scalable, event-driven microservices to deliver reliable performance at scale.
ONTAP tools for VMware vSphere supports:
  • Core virtual machine (VM) features such as protection and disaster recovery
  • VASA Provider for storage policy-based management
  • Storage policy-based management
  • Storage Replication Adapter (SRA)
High availability for ONTAP tools for VMware vSphere
ONTAP tools for VMware vSphere offers high-availability (HA) support to help maintain uninterrupted operation during failures.
The HA solution helps you recover quickly from the following types of outages:
  • Host failure - Only a single-node failure is supported.
  • Network failure
  • Virtual machine (guest OS) failure
  • Application (ONTAP tools) failure
You do not need to perform any additional configuration to enable HA for ONTAP tools for VMware vSphere.
Note
ONTAP tools for VMware vSphere doesn't support vCenter HA.
To use the HA feature, ensure that CPU hot-add and memory hot-plug are enabled during deployment or in the VM settings.
