ONTAP tools for VMware vSphere 10.2
Pair protected and recovery sites
Contributors netapp-jani
You should pair the protected and recovery sites created using your vSphere Client to enable Storage Replication Adapter (SRA) to discover the storage systems.
Note Storage Replication Adapter (SRA) does not support fan-out SnapMirror configurations. SnapMirror fan-out configurations are those where a source volume is replicated to two different destinations. These create a problem during recovery when VMware Live Site Recovery needs to recover the virtual machine from its destination.
What you will need
  • You should have VMware Live Site Recovery installed on the protected and recovery sites.
  • You should have SRA installed on the protected and recovery sites.
Steps
  1. Double-click Site Recovery on the vSphere Client home page and click Sites.
  2. Click Objects > Actions > Pair Sites.
  3. In the Pair Site Recovery Manager Servers dialog box, enter the address of the protected site's Platform Services Controller, and then click Next.
  4. In the Select vCenter Server section, do the following:
    1. Verify that the protected site's vCenter Server appears as a matching candidate to pair.
    2. Enter the SSO administrative credentials, and then click Finish.
  5. If prompted, click Yes to accept the security certificates.
Result
Both the protected and recovery sites will appear in the Objects dialog box.
