Upgrade from ONTAP tools for VMware vSphere 10.x to 10.6
You can directly upgrade ONTAP tools for VMware vSphere 10.4 or 10.5 to 10.6. To upgrade from ONTAP tools 10.0, 10.1, 10.2, or 10.3 to 10.6, first upgrade to 10.4 or 10.5.
Ensure all nodes are active before starting the upgrade.
Ensure the ONTAP system certificate and onboarded vCenter certificates are valid for at least 5 days. If the certificates expire sooner, the upgrade fails.
Ensure you have a fifth disk with a capacity of 100 GB on all nodes.
Verify that the node configuration matches the specifications in the table below.
| Deployment type | CPU cores per node | Memory (GB) per node | Disk space (GB) per node | Total CPU cores | Total memory (GB) | Total disk space (GB) |
Non-HA Small |
9 |
18 |
350 |
9 |
18 |
350 |
Non-HA Medium |
13 |
26 |
350 |
13 |
26 |
350 |
HA Small |
9 |
18 |
350 |
27 |
54 |
1050 |
HA Medium |
13 |
26 |
350 |
39 |
78 |
1050 |
HA Large |
17 |
34 |
350 |
51 |
102 |
1050 |
Enable low RPO backup and ensure one backup is visible in the vSphere Client interface. Download the backup folder before upgrade.
Low RPO backup is recommended. However, in non-HA deployment, you can take a quiesced snapshot of the ONTAP tools virtual machine before upgrading.
Refer to Edit Backup settings and Recover the ONTAP tools setup for more information about backup and recovery.
Upload ONTAP tools for VMware vSphere upgrade ISO to content library.
In the primary VM page, select Actions > Edit Settings. To identify the primary VM name:
Enable diag shell on any node
Run the following command:
grep sourceHost /opt/netapp/meta/ansible_vars.yaml
Select the content library ISO file in the edit settings window under the CD/DVD drive field.
Select the ISO file, check the Connected box for the CD/DVD drive field, and click OK.
Log in to the vCenter Server.
Locate the primary ONTAP tools VM and launch the web console.
Log in using the
maintcredentials. -
Enter 2 to select the System Configuration menu.
Enter 6 to select the Upgrade option.
Provide the vCenter credentials when prompted. This is the vCenter instance where the ONTAP tools is hosted.
If you are using ONTAP tools in a two-vCenter Server topology—where the appliance is hosted in one vCenter instance and manages another, you can assign a restricted role for the vCenter instance hosting the ONTAP tools. You can create a dedicated vCenter user and role with only the permissions required for OVF template deployment. For details, see the roles listed in Roles included with ONTAP tools for VMware vSphere 10.
For the vCenter instance that will be managed by ONTAP tools, make sure the vCenter user account has administrator privileges.
During the upgrade, if any onboarded storage backend certificates are missing Subject Alternative Name (SAN) entries, you will receive a prompt indicating the missing SAN. If you choose to proceed without validating the SAN, the upgrade will continue, but this is not recommended because of potential security risks.
When you upgrade, the following actions are performed automatically:
The gateway certificate is renewed with a 1-year validity period. When you remove the previous SRA adapter and upload the new 10.6 adapter, the SRA certificate validity changes from 10 years to 1 year.
Remote plug-in is upgraded
ONTAP and vCenter Server certificates are validated and added to ONTAP tools
Backup is enabled
If host cluster protection settings exist from ONTAP tools for VMware vSphere 10.5 or earlier, ONTAP tools converts them to granular datastore protection and creates a separate Cluster protection configuration navigation item.
After upgrading to ONTAP tools for VMware vSphere 10.6:
Monitor system alerts and plan to renew the gateway certificate before it expires in one year.
Remove the ONTAP tools 10.4 or 10.5 SRA adapter and upload the 10.6 SRA adapter tar file.
Run the install command after uploading SRA adapter tar. the Then, rescan the SRA adapters to update the VMware Site Recovery Storage Replication Adapters page.
Open Cluster protection configuration and verify that existing host cluster protection settings are present and mapped correctly.
For more information about granular datastore protection capabilities and eligibility, see Granular datastore protection eligibility criteria in ONTAP tools.
After upgrading you can:
Disable services from ONTAP tools Manager
Move from a non-HA setup to an HA setup
Scale up a non-HA small configuration to a non-HA medium, or to an HA medium or large configuration.
