Add storage backend
Storage backends are systems that the EXSi hosts use for data storage.
About this task
This task helps you to onbord the ONTAP cluster.
Steps
Launch
https://loadBalanceIP:8443/virtualization/ui/from browser with ONTAP tools administrator credentials provided during deployment. -
Select Storage Backends from the sidebar.
Select Add.
Provide the Server IP Address or FQDN, Username, and Password details and select Add.
Only IPV4 management LIFs are supported.
