Manage Storage threshold
Use the following Get threshold API to retrieve the configured storage threshold limits for volume and aggregate.
GET/virtualization/api/v1/vcenters/{vcguid}/storage-thresholds
Examples: Get the Storage thresholds per vCenter Server instance by vCenter guid
GET "/api/v1/vcenters/beded9ad-6bbb-4c9e-b4c6-691250bfe2da/storage-thresholds"
Use the following PATCH configure alarm for volume and aggregate to generate notification when configured threshold limits are reached.
PATCH/virtualization/api/v1/vcenters/{vcguid}/storage-thresholds
Examples: Update the Storage thresholds per vCenter by vCenter guid. Default limits are 80% for nearly-full and 90% for full. Modifying all threshold settings
{{{}PATCH "/api/v1/vcenters/beded9ad-6bbb-4c9e-b4c6-691250bfe2da/storage-thresholds"
Request Body
"volume":
{ "nearly_full_percent": 80, "full_percent": 90 }
"aggregate": {
"full_percent": 90
