Associate a storage backend with a vCenter Server instance
Associate a storage backend with the vCenter Server to create a mapping between the storage backend and the onboarded vCenter Server instance globally.
Steps
Launch ONTAP tools Manager from a web browser:
https://<ONTAPtoolsIP>:8443/virtualization/ui/ -
Log in with the ONTAP tools for VMware vSphere administrator credentials you provided during deployment.
Select vCenter from the sidebar.
Select the vertical ellipses against the vCenter Server instance that you want to associate with the storage backends.
Select the storage backend from the dropdown to associate the vCenter Server instance with the required storage backend.
