ONTAP tools REST API reference
The ONTAP tools for VMware vSphere 10 REST API reference contains details about all the API calls. This reference is helpful when developing automation applications.
You can access the ONTAP tools for VMware vSphere 10 REST API documentation online through the Swagger user interface. You need the IP address or FQDN of the ONTAP tools for VMware vSphere 10 gateway service as well as the port.
Steps
Type the following URL into your browser, substituting the appropriate IP address and port combination for the variable, and press Enter.
https://$FQDN_IP_PORT/Example
https://10.61.25.33:8443/ -
As an example of an individual API call, scroll down to the vCenters category and select GET next to the endpoint
/virtualization/api/v1/vcenters
