ONTAP tools for VMware vSphere 105
Configure network mappings in ONTAP tools
Contributors netapp-revathid
You should configure your resource mappings like VM networks, ESXi hosts, and folders on both sites to enable the mapping of each resource from the protected site to the appropriate resource at the recovery site.
You should complete the following resource configurations:
  • Network mappings
  • Folder mappings
  • Resource mappings
  • Placeholder datastores
Before you begin
You should have connected the protected and recovery sites.
Steps
  1. Log in to vCenter Server and select Site Recovery > Sites.
  2. Select your protected site and select Manage.
  3. Select Network Mappings > New in the manage tab to create a new network mapping.
  4. In the Create Network Mapping wizard, do the following:
    1. Select Automatically Prepare Mappings for Networks with Matching Names and select Next.
    2. Select the required data center objects for the protected and recovery sites and select Add Mappings.
    3. Select Next after mappings are created successfully.
    4. Select the object used earlier to create reverse mapping and then select Finish.
Result
The Network Mappings page displays the protected site resources and the recovery site resources. You can follow the same steps for other networks in your environment.
