Configure ONTAP tools for VMware vSphere
Virtual Storage Console (VSC) supports numerous environments. Some of the features in these environments might require additional configuration.
You might have to perform some of the following tasks to configure your ESXi hosts, guest operating systems, and VSC:
Verifying your ESXi host settings, including the UNMAP settings
Adding timeout values for guest operating systems
Regenerating the VSC SSL certificate
Creating storage capability profiles and threshold alarms
Modifying the preferences file to enable the mounting of datastores across different subnets
