The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
Your file is ready
You can manage your application, system, and network configurations by using the maintenance console of the ONTAP tools. You can change your administrator password and maintenance password. You can also generate support bundles, set different log levels, view and manage TLS configurations, and start remote diagnostics.
You must have installed VMware tools after deploying ONTAP tools to access the maintenance console. You should use “maint” as the user name and the password you configured during deployment to log in to the maintenance console of the ONTAP tools.
You must set a password for the “diag” user while enabling remote diagnostics.
You should use the Summary tab of your deployed ONTAP tools to access the maintenance console. When you click , the maintenance console starts.
Console Menu
Options
Application Configuration
Display server status summary
Start Virtual Storage Console service
Stop Virtual Storage Console service
Start VASA Provider and SRA service
Stop VASA Provider and SRA service
Change 'administrator' user password
Re-generate certificates
Hard reset keyStore and certificates
Hard reset database
Change LOG level for Virtual Storage Console service
Change LOG level for VASA Provider and SRA service
Display TLS configuration
Enable TLS protocol
Disable TLS protocol
System Configuration
Reboot virtual machine
Shutdown virtual machine
Change 'maint' user password
Change time zone
Add new NTP server
You can provide an IPv6 address for your NTP server.
Enable SSH Access
Increase jail disk size (/jail)
Upgrade
Install VMware Tools
Network Configuration
Display IP address settings
Change IP address settings
You can use this option to change the IP address post deployment to IPv6.
