Rebalance vVols datastores
ONTAP tools supports a command to rebalance FlexVol volumes in your datacenter. The main goal is to enable even space utilization among FlexVol volumes. ONTAP tools redistributes vVols among existing volumes based on space usage, thin provisioning, LUN count, and storage capability profiles.
The rebalancing of vVols datastore is performed by LUN move or file move. The criteria considered during vVols rebalancing are as follows:
NFS vVol datastores are not supported
Existing FlexVol volumes will not be resized and neither will new FlexVol volumes be added
Only FlexVol volumes that have same storage capability or volume attributes are rebalanced
FlexVol volumes with highest space utilization are considered for rebalancing
All vVols associated with a virtual machine are moved to the same FlexVol volumes
LUN and File count limit is retained
Rebalance is not performed if the delta between the FlexVol volumes space utilization is 10%
The rebalance command removes empty FlexVol volumes to provide space for other datastores. Thus, the command enables you to remove unwanted FlexVol volumes so that they can be removed from the datastore. The command intends to move all the vVols associated with a virtual machine to same FlexVol volume. There is a precheck performed by the command before rebalance is started to minimize failures. But even with successful precheck, the rebalance operation might fail for one or more vVols. When this happens, then there is no rollback of the rebalance operation. So, vVols associated with a virtual machine might be placed on different FlexVol volumes and will result in warning logs.
