Commands for managing audit settings for management activities
You use the security audit commands to manage which management activities are logged in the audit.log file. You use the cluster log-forwarding commands to manage destinations for forwarding the audit log to.
| If you want to… | Use this command… |
Specify that get requests from the ONTAP CLI or APIs should be recorded in the audit log (the |
Display the settings of the audit log |
Display audit entries merged from multiple nodes in the cluster |
Specify a forwarding destination for the audit log and security measures for its transmission |
Modify a destination for the audit log |
Delete a destination for the audit log |
Show the configured destinations for the audit log |
