Use HSTS for ONTAP web services
HTTP Strict Transport Security (HSTS) is a web security policy mechanism that helps protect websites against man-in-the-middle attacks such as protocol downgrade attacks and cookie hijacking. By enforcing the use of HTTPS, HSTS ensures that all communications between the user's browser and the server are encrypted. Beginning with ONTAP 9.17.1, ONTAP can enforce HTTPS connections for ONTAP web services.
HSTS is enforced by the web browser only after an initial secure HTTPS connection is established with ONTAP. If the browser does not establish an initial secure connection, HSTS will not be enforced. Refer to your browser documentation for information on HSTS management. |
For 9.17.1 and above, HSTS is enabled by default for newly installed ONTAP clusters. When you upgrade to 9.17.1, HSTS is not enabled by default. You must enable HSTS after the upgrade.
HSTS is supported for all ONTAP web services.
Advanced privileges are required for the following tasks.
Show HSTS configuration
You can show the current HSTS configuration to check if it is enabled and view the maximum age setting.
Use the
system services web showcommand to show the current web services configuration, including HSTS settings:cluster-1::system services web*> show External Web Services: true HTTP Port: 80 HTTPS Port: 443 Protocol Status: online Per Address Limit: 80 Wait Queue Capacity: 192 HTTP Enabled: true CSRF Protection Enabled: true Maximum Number of Concurrent CSRF Tokens: 500 CSRF Token Idle Timeout (Seconds): 900 CSRF Token Absolute Timeout (Seconds): 0 Allow Web Management via Cloud: true Enforce Network Interface Service-Policy: - HSTS Enabled: true HSTS max age (Seconds): 63072000
Enable HSTS and set the maximum age
Beginning with ONTAP 9.17.1, HSTS is enabled by default on new ONTAP cluster. If you upgrade an existing cluster to 9.17.1 or later, you need to manually enable HSTS on your cluster to enforce use of HTTPS. You can enable HSTS and set the maximum age. You can change the maximum age at any time if HSTS is enabled. Once HSTS is enabled, browsers will begin enforcing secure connections only after an initial secure connection is established.
Use the
system services web modifycommand to enable HSTS or modify the maximum age:system services web modify -hsts-enabled true -hsts-max-age <seconds>-hsts-max-agespecifies the duration in seconds for which the browser will remember to enforce HTTPS. The default value is 63072000 seconds (two years).
Disable HSTS
Browsers save the HSTS maximum age setting with each connection, and they continue to enforce HSTS for the entire duration even if HSTS is disabled on ONTAP. It will take up to the configured maximum age duration for the browser to stop enforcing HSTS after it is disabled. If a secure connection becomes impossible during this time, browsers enforcing HSTS will not permit access to ONTAP web services until the issue is resolved or the browser's maximum age expires.
Disable HSTS using the
system services web modifycommand:system services web modify -hsts-enabled false
