Manage notifications
In SaaS Backup Partner Central, you can add, modify, and delete notifications for different users.
You can enable or disable the following notifications:
Add user to role
Customer delete success
Customer onboard success
Customer delete failure
Customer onboard failure
Steps
From the dashboard, click
Select Notifications from the dropdown menu.
In Notification Management, you can add, modify, and delete notifications.
To add notifications, click
to add notifications to a user.In Add Notification, enter the email address for the user. Select notifications you want to enable and click Add.
To modify notifications, click
To delete notifications, click
