Migration overview
The migration command migrates metadata from SnapCenter 4.0 and later only. If you are using an earlier version of SnapCenter then you must first upgrade before you can migrate.
What is migrated
SnapCenter metadata, which includes storage systems, customized throttles, and email settings in the SnapCenter configuration file, policies, resource groups, backup metadata, and mounts. (the migration fails when it encounters prescripts or postscripts)
What is not migrated
Pre- and post-scripts that are configured for resource groups
Active guest file restore sessions, guest file restore credentials, and proxy VMs
Customized configuration settings in the
scbr.overrideconfiguration file -
If you begin migration when a guest file restore session is active, the session is deleted and the attached disk is not unmounted. You might have to delete the attached disk manually.
SnapCenter hosts are suspended
To ensure migration success, the migration command suspends all hosts that are registered with SnapCenter. After the migration process finishes successfully, SnapCenter hosts are resumed.
Where metadata is stored
Metadata for application-based VMDK backups is stored in the SnapCenter Server repository. Metadata for VM and datastore backups is stored in the SnapCenter VMware plug-in MySQL repository.
Migration workflow
You must use the Windows Powershell cmdlet invoke-SCVOVAMigration for each instance of the SnapCenter VMware plug-in that is registered with SnapCenter.
The cmdlet does the following:
Suspends all schedules to prevent job failures during the migration. After a successful migration, schedules are automatically re-enabled.
Migrates storage connections and metadata.
Creates backup schedules for post-migration backups.
Uninstalls the existing SnapCenter Plug-in for VMware vSphere from the Windows host.
If the SnapCenter VMware plug-in is installed on the SnapCenter Server host and protection is configured for the SnapCenter repository, then the migration process also uninstalls the Windows-based plug-in package that contains the SnapCenter Plug-in for VMware vSphere and the SnapCenter Plug-in for Windows, and then reinstalls the latest version of SnapCenter Plug-in for Windows to support the repository protection. The host type in the SnapCenter GUI changes from “vsphere” to “Windows”.
Removes the vSphere host and resource groups from the Windows SnapCenter Server.
Activates the backup jobs on the Linux-based SnapCenter VMware plug-in.
Registers the vSphere host for the SnapCenter VMware plug-in with SnapCenter to support application-based backups of virtualized databases and file systems (application over VMDK backups).
