Deploy SnapCenter Plug-in for VMware vSphere
To use SnapCenter features to protect VMs, datastores, and application-consistent databases on virtualized machines, you must deploy SnapCenter Plug-in for VMware vSphere.
For VMware vCenter 7.0.3 and later versions, follow the steps in Download the Open Virtual Appliance (OVA) to import the certificates to vCenter.
In your browser, navigate to VMware vSphere vCenter.
For IPv6 HTML web clients, you must use either Chrome or Firefox. -
Log in to the VMware vCenter Single Sign-On page.
On the Navigation pane, right-click any inventory object that is a valid parent object of a virtual machine, such as a datacenter, folder, cluster, or host, and select Deploy OVF Template to start the VMware deploy wizard.
On the Select an OVF template page, specify the location of the
.ovafile (as listed in the following table) and click Next.On this wizard page… Do this… Select a name and folder
Enter a unique name for the VM or vApp and select a deployment location.
Select a resource
Select a resource where you want to run the deployed VM template.
Review details
Verify the
.ovatemplate details.License agreements
Select the checkbox for I accept all license agreements.
Select storage
Define where and how to store the files for the deployed OVF template.
Select networks
Select a source network and map it to a destination network.
Customize template
In Register to existing vCenter, enter the vCenter credentials.
In Create SnapCenter Plug-in for VMware vSphere credentials, enter the SnapCenter Plug-in for VMware vSphere credentials.Make a note of the username and password that you specify. You need to use these credentials if you want to modify the SnapCenter Plug-In for VMware vSphere configuration at a later time. In Setup Network Properties, enter the network information.
In Setup Date and Time, select the time zone where the vCenter is located.Ready to complete
Review the page and click Finish.
All hosts must be configured with IP addresses (FQDN hostnames are not supported). The deploy operation does not validate your input before deploying. -
Navigate to the VM where SnapCenter Plug-in for VMware vSphere was deployed, then click the Summary tab, and then click the Power On box to start the SnapCenter VMware plug-in.
While the SnapCenter VMware plug-in is powering on, right-click the deployed SnapCenter VMware plug-in, select Guest OS, and then click Install VMware tools.
The deployment might take a few minutes to complete. A successful deployment is indicated when the SnapCenter VMware plug-in is powered on, the VMware tools are installed, and the screen prompts you to log in to the SnapCenter VMware plug-in.
The screen displays the IP address where the SnapCenter VMware plug-in is deployed. Make a note of the IP address. You need to log in to the SnapCenter VMware plug-in management GUI if you want to make changes to the SnapCenter VMware plug-in configuration.
Log in to the SnapCenter VMware plug-in management GUI using the IP address displayed on the deployment screen using the credentials that you provided in the deployment wizard, then verify on the Dashboard that the SnapCenter VMware plug-in is successfully connected to vCenter and is enabled.
Use the format
https://<appliance-IP-address>:8080to access the management GUI.The maintenance console user user name is set to
maintby default and you can set a password at the time of installation. -
Log in to vCenter HTML5 client, then click Menu in the toolbar, and then select SnapCenter Plug-in for VMware vSphere
