SnapCenter Plug-in for VMware vSphere 4.8
How restore operations are performed
For VMFS environments, the SnapCenter Plug-in for VMware vSphere uses clone and mount operations with Storage VMotion to perform restore operations. For NFS environments, the plug-in uses native ONTAP Single File SnapRestore (SFSR) to provide greater efficiency for most restore operations. For vVol VMs, the plug-in uses ONTAP Single File Snapshot Restore (ONTAP SFSR) and SnapMirror Restore for restore operations. The following table lists how restore operations are performed.
Restore operations From Performed using
VMs and VMDKs
Primary backups
NFS environments: ONTAP Single File SnapRestore
VMFS environments: Clone and mount with Storage VMotion
VMs and VMDKs
Secondary backups
Deleted VMs and VMDKs
Primary backups
Secondary backups
NFS environments: Clone and mount with Storage VMotion
VMs and VMDKs
VM-consistent primary backups
VMs and VMDKs
VM-consistent secondary backups
vVol VMs
Crash-consistent primary backups
ONTAP Single File SnapRestore for all protocols
vVol VMs
Crash-consistent secondary backups
ONTAP SnapMirror Restore for all protocols
FlexGroup VMs
Primary backups
NFS environments:
* ONTAP Single File SnapRestore if you are using ONTAP Version 9.10.1 and later
* Clone and mount with Storage VMotion on ONTAP previous versions
VMFS environments: Not supported for FlexGroups
FlexGroup VMs
Secondary backups
NFS environments:
  • ONTAP SnapMirror Restore if you are using ONTAP Version 9.10.1 and later
  • Clone and mount with Storage VMotion for ONTAP previous versions
Note You cannot restore a vVol VM after a vVol container rebalance.
Guest file restore operations are performed using clone and mount operations (not Storage VMotion) in both NFS and VMFS environments.
Important During a restore operation, you might encounter the error Host unresolved volumes is null or Exception while calling pre-restore on SCV….Error mounting cloned LUN as datastore… This occurs when the SnapCenter VMware plug-in attempts to resignature the clone. Due to VMware restrictions, the SnapCenter VMware plug-in cannot control the automatic resignature value in advanced ESXi configurations.
