Manage policies
You can create, modify, view, detach, and delete backup policies for SnapCenter Plug-in for VMware vSphere. Policies are required to perform data protection operations.
Detach policies
You can detach policies from a SnapCenter VMware plug-in resource group when you no longer want those policies to govern data protection for the resources. You must detach a policy before you can remove it or before you modify the schedule frequency.
The guidelines for detaching policies from the SnapCenter VMware plug-in resource groups differ from the guidelines for SnapCenter resource groups. For a VMware vSphere client resource group, it is possible to detach all policies, which leaves the resource group with no policy. However, to perform any data protection operations on that resource group, you must attach at least one policy.
In the left Navigator pane of the SCV plug-in, click Resource Groups, then select a resource group and click Edit.
On the Policies page of the Edit Resource Group wizard, clear the check mark next to the policies you want to detach.
You can also add a policy to the resource group by checking the policy.
Make any additional modifications to the resource group in the rest of the wizard, and then click Finish.
Modify policies
You can modify policies for a SnapCenter Plug-in for VMware vSphere resource group. You can modify the frequency, replication options, Snapshot copy retention settings, or scripts information while a policy is attached to a resource group.
Modifying SnapCenter VMware plug-in backup policies differs from modifying backup policies for SnapCenter application-based plug-ins. You do not need to detach policies from resource groups when you modify the plug-in policies.
Before you modify the replication or retention settings, you should consider the possible consequences.
Increasing replication or retention settings
Backups continue to accumulate until they reach the new setting.
Decreasing replication or retention settings
Backups in excess of the new setting are deleted when the next backup is performed.
To modify a SnapCenter VMware plug-in policy schedule, you must modify the schedule in the plug-in resource group. |
In the left Navigator pane of the SCV plug-in, click Policies, then select a policy and click Edit.
Modify the policy fields.
When you are finished, click Update.
The changes take effect when the next scheduled backup is performed.
Delete policies
If you no longer require a configured backup policy for SnapCenter Plug-in for VMware vSphere, you might want to delete it.
You must have detached the policy from all resource groups in the virtual appliance for SnapCenter before you can delete it.
In the left Navigator pane of the SCV plug-in, click Policies, then select a policy and click Remove.
In the confirmation dialog box click OK.
