The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
REST API workflows to attach and detach VMDKs
To perform attach and detach operations for VMDKs using the SnapCenter Plug-in for VMware vSphere REST APIs, you must follow the prescribed sequence of REST API calls.
For each REST API, add https://<server>:<port> at the front of the REST API to form a complete endpoint.
To attach VMDKs, follow this workflow:
| Step |
REST API |
Comments |
1 |
Go to http://<vCenter-IP>/mob |
Find the VM moref from the VMware Managed Objects URL.
Note the moref for the VM to which you want to attach a VMDK. |
2 |
/4.1/vm/{moref}/backups
Get VM Backups gets a list of backups for the specified VM.
Pass the moref from Step 1.
Note the backupId of the backup you want to restore.
3 |
/4.1/vm/{moref}/backups/
{backupId}/vmdklocations
Get VMDK Locations gets a list of VMDKs for the specified VM.
Pass the backupId from Step 2 and the moref from Step 1.
Note the vmdkLocationsList information.
4 |
/4.1/vm/{moref}/attachvmdks
Attach VMDKs attaches the specified VMDK to the original VM.
Pass the vmdkLocationsList from Step 3 to the vmdkLocations attribute.
To attach a VMDK to a different VM, pass the moref of the target VM in the alternateVmMoref attribute.
To detach VMDKs, follow this workflow:
| Step |
REST API |
Comments |
1 |
Note the moref for the VM on which you want to detach a VMDK. |
2 |
3 |
4 |
/4.1/vm/{moref}/detachvmdks
Detach VMDKs detaches the specified VMDK.
Pass the VMDK vmdkLocationsList details from Step 3 to the vmdksToDetach attribute.
