REST APIs to generate audit logs
Contributors netapp-revathid
You can collect the audit log details from swagger rest APIs as well as the SCV plugin user interface.
Given below are the swagger rest APIs:
  1. GET 4.1/audit/logs: Get audit data for all logs
  2. GET 4.1/audit/logs/{filename}: Get audit data for a specific log file
  3. POST 4.1/audit/verify: Trigger audit log verification.
  4. GET 4.1/audit/config: Get the audit and syslog server config
  5. PUT 4.1/audit/config: Update the audit and syslog server config
To generate audit logs for VMware vSphere client jobs using the SnapCenter Plug-in for VMware vSphere REST APIs, you must use the REST API calls for VMware vSphere.
For each REST API, add https://<server>:<port>/api at the front of the REST API to form a complete endpoint.
Use the following REST APIs in the Jobs section to get detailed information on jobs:
REST API Comments
4.1/audit/logs
returns audit log files with integrity data
get specific audit log file with integrity data
4.1/audit/verify
triggers audit verification
4.1/audit/syslogcert
updates the syslog server certificate
