Overview
The SLP service broadcasts WBEM services. When the SLP service is enabled, client applications can discover the CIMOM server. You can also specify SLP configuration settings using the slp.conf file.
If the SLP service is not already enabled, you can start the SLP service by using the smis slpd start command. To stop the SLP service, use the smis slpd stop command.
