NetApp SMI-S Provider
Overview
Contributors netapp-maireadn netapp-revathid
NetApp SMI-S Provider 5.2.7 enables you to manage and monitor storage systems and to manage LUNs and volumes of storage systems, CIMOM configuration settings, and CIM server users.
NetApp SMI-S Provider is a command-based interface that detects and manages platforms that run ONTAP software. SMI-S Provider uses Web-Based Enterprise Management (WBEM) protocols, which enable you to manage, monitor, and report on storage elements.
NetApp SMI-S Provider follows schemas standardized by two organizations:
SMI-S Provider replaces the use of multiple managed-object models, protocols, and transports with a single object-oriented model for all components in a storage network.
