NetApp SMI-S Provider
Overview
Before using SMI-S Provider for the first time, you must validate your preliminary configuration.
Perform the following tasks before using SMI-S Provider:
  1. From NetApp SMI-S Provider, verify that the CIM server is started.
  2. Add a CIM server user.
  3. Verify management of the storage system by adding at least one storage system for SMI-S Provider.
  4. Optional: Generate a self-signed certificate for the CIMOM.
By default, authentication is enabled for SMI-S Provider.
After you have successfully performed this validation, you can begin to manage your storage systems using NetApp SMI-S Provider.
