Overview
You can use the smis commands to manage storage systems and to display information about the CIM object manager.
Help is available for the smis command by using the -help option.
smis
-helpDisplays a command summary.
smis
-helpexamplesDisplays usage examples.
smis
-help subcommandDisplays help for the specified subcommand.
The default timeout value for the smis tool is 180 seconds.
