Access is denied error
Message
Access is denied. -
This message occurs in two possible situations:
If you are not logged in as Administrator when accessing SMI-S Provider from the Start menu shortcut
If the SMI-S Provider directory is not pointing to
C:\Program Files (x86)\NetApp\smis\pegasus\bin
Corrective action
Complete the action that corresponds to the situation:
Log in with Administrator-level privileges and reopen SMI-S Provider from the Start menu, or right-click and select Run as administrator.
Log in with Administrator-level privileges and manually change the directory to
C:\Program Files (x86)\NetApp\smis\pegasus\bin.
