NetApp SMI-S Provider
Cannot connect to localhost:5988
NetApp SMI-S Provider can fail to connect to localhost:5988 when the required connection settings are disabled or misconfigured, or when the provider has stopped responding. Verify your connection settings and restart the provider to resolve the issue.
  • Message
    Cannot connect to localhost:5988. Connection failed. Trying to connect to localhost:5988
  • Description
    This message occurs when HTTPS connections are disabled or the HTTPS port is not set to 5988, or if the provider has stopped working and remains in a hanging state.
  • Corrective action
    Verify that the values of enableHttpsConnection and httpsPort are correct:
    cimconfig -g enableHttpConnection
    cimconfig -g enableHttpsConnection
    cimconfig -g httpPort
    cimconfig -g httpsPort
    If enableHttpConnection or enableHttpsConnection is not set to true, enter the following commands:
    cimconfig -s enableHttpConnection -p
    smis cimserver restart
    If httpPort is not set to 5988, enter the following commands:
    cimconfig -s httpPort=5988 -p
    If the provider has stopped working and remains in a hanging state, open Task Manager and end the process, and then restart the provider.
