Cannot connect to localhost:5989
NetApp SMI-S Provider can fail to connect to localhost:5989 when HTTPS connections are disabled, the HTTPS port is misconfigured, or the provider has stopped responding. Verify your HTTPS connection settings and restart the provider to resolve the issue.
Message
Cannot connect to localhost:5989. Connection failed. Trying to connect to localhost:5989 -
This message occurs when HTTPS connections are disabled or the HTTPS port is not set to 5989, or if the provider has stopped working and remains in a hanging state.
Corrective action
Verify that the values of
enableHttpsConnectionandhttpsPortare correct:cimconfig -g enableHttpsConnectioncimconfig -g httpsPortIf
enableHttpsConnectionis not set to “true”, enter the following commands:cimconfig -s enableHttpsConnection -psmis cimserver restartIf
httpsPortis not set to 5989, enter the following commands:cimconfig -s httpsPort=5989 -psmis cimserver restartIf the provider has stopped working and remains in a hanging state, open Task Manager and end the process, and then restart the provider.
