cimuser
You can use the cimuser command to add, remove, delete, modify, and list CIM server users, as well as manage their passwords.
Syntax
cimuser options
Location
C:\Program Files (x86)\NetApp\smis\pegasus\bin
Privilege level
Administrator (Windows)
Options
-a
Adds a CIM user.
-h, --help
Displays help for the
cimusercommand. -
-l
Lists CIM users.
-m
Modifies a CIM user's password. The password can be between 4 through 32 characters long.
-n
Creates a new password for the specified user. The password can be between 4 through 32 characters long.
-r
Removes a specified CIM user.
-u
Specifies a CIM user name.
--version
Displays the version of the CIM server.
-w
Specifies the password for the specified user.
Example
Create a CIM user named sydney with a password of password1:
cimuser -a -u sydney -w password1 User added successfully.
