Connection refused
A Connection refused message indicates that the CIM server used by NetApp SMI-S Provider has not been started. Verify the CIM server status and start it if needed.
Message
Connection refused -
Cause
The CIM server has not been started.
Corrective action
Navigate to the
bindirectory in the directory in which you installed NetApp SMI-S Provider, and enter the following command to verify that the CIM server is started:smis cimserver statusIf the CIM server is not running, enter the following command:
smis cimserver start
