NetApp SMI-S Provider
Issue entering passwords containing special characters
Passwords that contain special characters can cause the smis command to fail in a Windows environment. Enclose such passwords in double quotes to enter them successfully.
  • Issue
    In English-language operating systems, using a password that contains special characters with the smis command does not work in a Windows environment. This issue has not been tested with non-English operating systems.
  • Cause
    In Windows, the following characters, plus any spaces, are considered special characters and cause password input to fail if the password is not enclosed in quotation marks:
  • Corrective action
    If a password contains spaces or special characters, enclose it in double quotes (" ") when you use it in the smis command. Note that the quote character (") is a special character and should never be used in your password.
Issuing passwords with special characters
smis add 1.2.3.4 Administrator "pass word"
smis add 1.2.3.4 Administrator "pass&word"
