Hardware requirements
You must verify that the Windows host meets the minimum hardware requirements before installing NetApp SMI-S Provider.
| Hardware | Requirements |
Memory |
Disk space |
Enabling logging and tracing requires additional disk space of up to 1 GB, depending on the log and trace file rotation settings. You must have 100 MB temporary disk space available for installation. |
CPU |
